185 flywheel gear
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: 185 flywheel gear
    Posted: 07 Oct 2022 at 8:04pm
Is the flywheel gear on a 185 reversible, doesn't look to be any difference in front or back of the teeth. Have a bit of wear in one spot, good time to fix while I have it split.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2022 at 11:24pm
generally the engagement side has chamfered teeth and the other does not. If it's champhered on both sides do it.
Edited by SteveM C/IL - 07 Oct 2022 at 11:26pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 8:05am
They usually wear in 3 spots.  You can heat it up and rotate it to a spot that is not worn down.  IF not, put a new one on and you will never have to touch it again.  Most flywheels on ACs are one way - chamfered on one side only.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 8:26am
Agco part # is 74023904V  for 85.80 I would change the gear
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 5:03am
I would do what Alvin said...put a NEW one on and be done with it, while you have it apart...
This page was generated in 0.043 seconds.
