12 Volt Alternator
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Topic: 12 Volt Alternator
    Posted: 06 Oct 2022 at 3:46pm
I usually use a one wire GM alternator when converting a tractor to 12 volts.  I want to convert a CA and the GM alternators don't fit well between the drag link and engine.  I have a smaller three wire alternator that was taken off a tractor at some point.  I can't find any ID on the alternator.   If anyone recognizes the alternator in the pictures and knows how it should be wired, please reply.  One wire is green and the other green with a pink stripe, but I don't know which is the exciter wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 4:01pm
It looks like the small DENSO alternator used on Toyota and Hondas... I dont know which color is which..
Edited by steve(ill) - 06 Oct 2022 at 4:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 4:08pm
it would appear the EXCITATION might be the one FURTHEST from the BAT terminal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 4:17pm
another confirmation...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 4:57pm
Steve, thanks for the help.  That would be the same as a GM three wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 5:54pm
If you find out it's DOA, you might try the CS-130 series from GM (late 90s- ??? )
All my D-14s have them,smaller than the old,big thing that most have on them.
Possible option ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 6:05pm
here is a photo of a version of the CS130 that Jay mentions, ( small DELCO) on a B tractor... I think this is the same unit that Steve B&B makes the kits for..
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 7:02pm
With a well made mount the regular GM alternator will fit behind the CA drag link And still use the OEM size belt.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 9:55pm
I use the "CS"121 Alternator or the pint size Denso Alternator for my C & CA kits. They fit nice behind the drag link and give you amble room for adjusting the belt. Doesn't matter how stout a bracket you make, you're still stuffing the Alternator in a tight spot. Going with a smaller unit to do the charging chores is the way to go. Also, you're much better off wiring the Alternator for a 3 wire system.  Quite a bit better system for a Tractor. Instant charging as soon as the Tractor fires up. It's two more wires. It ain't hard to do. The diagrams that Steve posted will work fine for your application. BTW, that looks like a Denso that came on a JD or a Skidloader.
Steve@B&B
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2022 at 2:16pm
What does the decal say?
Edited by 55allis - 07 Oct 2022 at 2:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2022 at 4:35pm
Label is just a bar code.  I Googled the number, but did not find a match.
