190xt harmonic balancer removal question |
youngorange2000
Joined: 27 Mar 2019 Location: eastcentral MN Points: 326 |
Topic: 190xt harmonic balancer removal questionPosted: 06 Oct 2022 at 3:29pm |
I need to remove the front cover on my xt. The problem is all of the harmonic balancer puller tools in town are too small. Would it be safe to remove with a three jaw puller? Any suggestions would be appreciated
DrAllis
Thanks(1)
Posted: 06 Oct 2022 at 6:01pm |
NOOOOOO !!!! You CANNOT pull on the O.D. of any rubber isolated crankshaft pulley !!! Make yourself a puller: You goal is to pull from three of the six holes on the center hub. Use a 1 inch thick plate. Drill your holes to match three of the hub holes. Drill a 1 inch+ hole dead center. Use a 1 inch fine thread bolt and nut to tack weld under the center hole area. Use grade 8 bolts (7/16") long enough to position the 1" NF on the push side of the plate. Loosen the crankshaft bolt 2 full turns and press against the head of it. It sometimes takes 10 TONS of pressure to get it loose. Make the plate big enough you can drill three more holes for the 426 engine and have one tool for both.
Edited by DrAllis - 06 Oct 2022 at 6:02pm |
DougG
Posted: 06 Oct 2022 at 6:31pm |
And they pop when they finally let go !
wildcat2
Joined: 03 Aug 2011 Location: United States Points: 113 |
Thanks(1)
Posted: 07 Oct 2022 at 7:25am |
Dr. Allis your reply should probably be posted in the knowledge section for prosperity.
JPG AUSTRALIA
Thanks(2)
Posted: 08 Oct 2022 at 12:07am |
Wildcat2 I think that most of dr allis answers should be archived in the knowledge section.😀
