AC D grader, Gas to Diesel
Cooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cooper Quote  Post ReplyReply Direct Link To This Post Topic: AC D grader, Gas to Diesel
    Posted: 05 Oct 2010 at 1:08pm
I just found out you can't use a IPad to log in.  Sorry
I have a 1960's D motor grader. We think it has about a 65 HP gas engine, 4 cyl.
The timing gear went out and they want almost $900 for the two gears.
I would like to put a diesel in it.  What kind of diesel can I buy that would fit.
Also where do you find one.
Thanks
Wayne Cooper
Charles Craig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles Craig Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 3:56pm
     When my "D" grader arrived with the oil and coolant too friendly, Iput a wd45 used engine in it. has enough power to spin the tires and wasnt too  difficult by my self.   CC
AC BD3 roadgrader "D" road grader SIX "old" cars Farmall 300
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 4:12pm
The D grader uses the 226 gas engine common to the popular D17 and 175 farm tractors. There should be used parts and even used engines available for less trouble and cost than trying to switch to a diesel engine. The diesel engine used for these same farm tractors was used in the DD graders but the engine is slightly longer so some modifications are still required. Try posting on the farm equipment section for your timing gears. Did the timing gears break because of a governor weight failure?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 6:27pm
Lots of good 226 engines available out of Gleaner E combines.
cocochen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cocochen Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 3:49am
Edited by CTuckerNWIL - 11 May 2011 at 12:17pm
This page was generated in 0.172 seconds.
