used fire hoses
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: used fire hoses
    Posted: 02 Oct 2022 at 7:38pm
OK, so I got a 'deal'...
FREE 5by8 utility trailer with several hundred feet of used fire hoses. NO brass ends but the trailer's FULL of hoses....
so $64 question...
WHAT do I do with the hoses ???
Wife'd hang me with one IF she could lift a section over the tree......
Jay
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2022 at 7:55pm
They make a good discharge hose on my pool layer flat I can mow over it. We use to use them as tow ropes. But if theve been laying in the sun they are trash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2022 at 8:30pm
I cut one into 2 ft lengths... Slide the Tie Straps thru them when strapping down around sharp edges of equip or trailer....... but you only need about 20 ft !!
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2022 at 11:58pm
I use them to cover and protect the hydraulic hoses on my skid steer attachments. Keeps the sun from damaging them while they aren't in use and keeps tree branches from scraping on them in the timber when clearing brush.
Got mine from the local firehouse when they were switching out hoses a few years back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 4:30am
Free firewood...Wink
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 5:21am
Weather strip around the edge of garage doors. Ditto the tow strap and use common sense if you do it. Good idea about the hydraulic hose protector.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 8:51am
I just cut some old fire hose to make new flaps at the front of forage wagons to keep feed form falling out when unloading.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 9:24am
Also great to feed your chains through so you protect paint
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 9:35am
They are also used around boat docks for protect the sides of the boats. Many other good uses some of which have already been mentioned. What size hose? Hundred foot rolls of 5 inch supply can be a pita to handle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 10:39pm
when I worked for a tow company, they ran chains thru them to use when they had to pick up motorcycles. all the uses above i've seen too. keep them inside and sell a few lengths at garage sales thru the year. also run a garden hose thru one when laying across the driveway/road, will protect the hose when you drive over it. be a good sump pump hose and push bumper cushion.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 11:58pm
Makes excellent dock fender material, with exception that it tends to accumulate moss and other marine growth unless it's up at least a foot and a half from the waterline.
If you have a push bumper on a work truck or wrecker, hang them in vertical strips, and then hang another layer between each, it will make your contact much more gentle.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 10:18am
 Yes, sounds like a lots of ideas, just advertise it and hopefully you will come out ahead
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 10:30am
I still need  about 1,400 feet of either 3" or 2" for my garden water idea next year.
I have enough pumps to use as boosters to run from the river to my garden and big tankers to fill at the gate and pump to the crops from the tankers with smaller pumps.
Its just one one of my ideas that would work if I can find hoses. Got the pumps and the big tankers ready to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2022 at 6:57am
AC...be careful pumping out of the river, fish and sand really tear up pumps
