twine
donslick72@gmail.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donslick72@gmail.com Quote  Post ReplyReply Direct Link To This Post Topic: twine
    Posted: 05 Oct 2010 at 10:11am
What do you fellows us for twine in a Rotor-Baler?  Thank you in advance . Don Slick
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 10:17am
I was under the impression that you can only use binder twine as regular baling twine is to heavy.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 10:59am
I use binder twine.  I could probably get you some if you need some.  Ill have to check on the price and shipping.
 Joe
Life is simpler when you plow around the stump.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 11:17am
Our local supply store still has twine labeled for use in Roto Baler!
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 11:30am
I use binder twine, But I see that Menards caries "sisal" twine which looks almost identical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote donslick72@gmail.com Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 11:50pm
I agree that, I understand binder twine should be used, but I haven't been able to find any. Normal baler twine won't even fit in the box is too heavy, tried a plastic baler twine it is too small and won't stay in the tension wheel.  Don
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 7:13am
My Father bought one of the first Roto Balers when they came out in 1947 and ran it until he died in 1996. I can tell you for sure BINDER TWINE. Nothing else fits, feeds properly or cuts off better. He sent me to the Co-op once for binder twine and I came back with baler twine. We ALL got in trouble! LOL Get your winrows wide--- not tall. Put two or 3 just side by side. Feeds better and more evenly. Raking was my job with the old 45. (which I still have). Truly a remarkable machine- way ahead of its time!
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:22am
when i use to buy rotor baler twine it came 6 balls to a pkg.but i believe the binder twine you can buy now has 4 balls per pkg.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:24am
Tractor supply has it, it where all the rope is at, look on the top shelf and you will see little balls of Sisal Twine
1968 D15D,1962 D19D
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:35am
Tom Yaz sells roto baler twine on his web site. 4 per bundle. $25.00.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:38am
Toms is cheaper than Tractor supply, they want 15 bucks a ball.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:45am
I still get it at my local farm and home. They still carry belts and twine. I will support them as long as they do. I enjoy the looks I get almost as much as running it!
