dialing in Zenith idle mixture screw |
Post Reply ![]() |
Chad_in_PDX ![]() Bronze Level ![]() Joined: 01 Sep 2022 Location: Portland Points: 17 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Sep 2022 at 10:21pm |
I’ve got a B that I’m still getting familiar with.
What is the process for dialing in (leaning out) the idle mixture? Right now my mixture screw is backed out 1.5 turns. This is on a Zenith 10698A. Going by smell, the engine is running rich. Also, the plugs are starting to get sooty. Thanks Chad |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11991 |
Usually, one and a half is a good starting point for the air/fuel adjustment. Every engine is different for adjusting to get that "right" spot, but if you're blowin' black smoke with the mix screw only 1 1/2 turns out, you might have a high float problem, or junk stuck in the needle seat causing the engine to run rich. The Carburetor might need some attention internally. It might have a lot of rust n' junk in it causing your rich issue..... HTH Steve@B&B
Post Reply ![]() |
