D 15II Head (Clean out plug)
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: D 15II Head (Clean out plug)
    Posted: 04 Oct 2010 at 12:07pm
Lots of corosion and a mess around the front plug called the clean out plug in the parts book.  I got the bolt and packing/seal out fine.
Was wondering bout that item called a nut.  I got a few threads left in the head but it would be nice to get that refurbished.
Is the part called the nut replaceable and how does it come out and go back in that round hole?
thanx
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 5:05pm
Order the new plug assembly and you'll see what it's all about......you need to get a bolt attached to it and pull it out thru all the rust that's holding it in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 7:08pm
thanks Dr Allis.
I did not know it came as an assembly.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 7:46pm
Interesting that this plug doesn't exist on the D14.  I had previously thought that there was more commonality between the 149 and 160 heads...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 5:47pm
had not realized it has been this long.  Norm found me the assembly and it is now installed.
I wonder what the engineer was thinking about when he decided to put that thing in there?
M Diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 6:35pm
Never looked at this particular setup, but is this an access hole to clean the head after casting or something else entirely? Just curious.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 8:10pm
  we have more rubber plugs working on a replacement also   1-800-254-3116
   costly from agco with shipping
