Tach drive orientation
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: Tach drive orientation
    Posted: 15 Sep 2022 at 9:14am
Where is the tach drive supposed to go? This just don't look right. G2800, early 190XT
I have not found any pictures or descriptions in any manuals I have, operators, parts,tech, and I have both, IT and AC shop books..
Edited by Michael V (NM) - 15 Sep 2022 at 9:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2022 at 9:34am
I think someone has the distributer 180 degrees off. Good luck with that as it may require re-clocking the engine oil pump to get it where it should be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2022 at 9:47am
That's what I guessed, 180 off...
I was hoping to get #1 TDC, pull the wires, twist the distributor counterclockwise about 1/2 turn, an put the wires back in...correct order,of course, and re-time
or will the distributor not go full around? Well at least halfway, I think the tach drive will hit the block
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2022 at 10:31am
I thought the tach drive rupture was pointed to the rear and on the outside away from the block. Been too many years ago and quite frankly my diesel population was about 96% versus gassers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2022 at 11:21am
I figured it would point to the rear,that way the cable don't have a 90 degree turn. I'm hoping I can at least rotate the distributor about 120 degrees counterclockwise, so the cable don't have that sharp bend...
Not that it makes any difference,,this is a LP...
My brother has a G combine with a 2800,,,I may go see if it has a tach drive,an see how it's oriented.....I know they don't have a cable,but if if has the drive,,,give me an idea anyways...
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 3:12pm
I had my XT gas out today so checked on tach cable. It is just like yours makes a u turn and is clamped to the hydraulic cooler steel line under the hood
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 3:49pm
Hey,,thanks Steve,,looks better routed that way,,when I get a new cable,I know how it's done
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2022 at 4:12pm
Mine points fwd and out big loop around and to dash. Mine apears if it was pointed back it would occupy the same place as the hyd lines
