Remove A/C clutch |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8404 |
Topic: Remove A/C clutchPosted: 12 Sep 2022 at 5:54pm |
What’s the best way to remove the clutch from the compressor? Old fashioned square-ish compressor, 1995 3406. Clutch fell off, have another complete unit, but not the equipment to evacuate the system. Figure I would swap clutch. How can I hold the clutch and unscrew the center bolt at the same time?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 12 Sep 2022 at 7:41pm |
A/C clutch tool...duh
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 12 Sep 2022 at 8:05pm |
Hey Lars,,,having had to "DO OVERS" enough times when I tried to "save" a little money and time by NOT evacuating system,, I NOW always evacuate the system, especially in the hotter months due to excess humidity and that is what you trying to get out. I don't think Oriellys has the vaccum pumps but they do have the clutch puller tool tho. Good Luck!!
Lars(wi)
Posted: 12 Sep 2022 at 9:04pm |
Thanks guys, I haven’t ever seen a clutch puller tool, guess I’ll have to do a search
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35696 |
Posted: 13 Sep 2022 at 4:35am |
Getting the bolt out should not be that tough, just have to hold the remnant of the drive plate to break loose and unscrew. That drive plate IIRC is threaded for a 5/8 USS bolt to push it off the taper shaft.
fixer1958
Posted: 13 Sep 2022 at 8:13am |
Big ass channel locks
farmboy520
Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Posted: 13 Sep 2022 at 9:29am |
Or the Bigazz brand of channel locks
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
