Deutz 913C cylinder shims |
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 261 |
Topic: Deutz 913C cylinder shimsPosted: 12 Sep 2022 at 12:20pm |
Replacing # 1 & 2 cylinders jug, piston & heads, how many & what thickness of shims should I have on hand to to install on jugs to make the intial clearance check, I would rather remove shims than have to add.All parts that I,m using have never been & don't need to be machined. Thanks Dave
DrAllis
Posted: 12 Sep 2022 at 4:37pm |
Add a couple to the old stack you removed would be a good place to start.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3662 |
Posted: 12 Sep 2022 at 8:05pm |
Always add more shims than needed. Assemble the cylinder and use a thick solder off a roll to insert in the injector hole - tighten the head - no need to final torque now - then turn the engine over to allow piston to smash the solder - remove solder and measure the piston to head clearance - then do the math , loosen the head bolts and lift the sleeve and cut off enough shims to obtain correct clearance. Depending on how high your math scores were in school would determine if a second check was necessary :-)
