Hd6g starter question
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g starter question
    Posted: 08 Sep 2022 at 7:55pm
New loader, Bending wouldn't engage... disassembled, found this pin separated from the engagement lever. Do you know if this pin is welded onto the lever originally? Or just pressed in? Starter has been rebuilt at least once, and otherwise looks fine
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2022 at 8:51pm
Solved this, drilled out back of lever, inserted the pin I made out of the 88 F250 clutch master cylinder rod, and welded the back side of it. Reassembled starter, works like new.
This page was generated in 1.781 seconds.
