Best way,,,,,,
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Best way,,,,,,
    Posted: 08 Sep 2022 at 11:38am
To separate coolant out of used oil?
Have a 8,000 gal storage for used oil, about 20 in on the bottom is red coolant, from oil changing, leaking oil coolers etc. Not all engine oil, some gear oil, hyd fluid, diesel etc. stuck a suction pipe down, and pumped out till black showed coming out nozzle, but has the consistency of water.
Gonna fill a couple totes of this mix, and see if it will separate out.
Are there any other tricks to this? The oil recyclers don’t want any coolant in the batch.
Thanks in advance.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 12:31pm
Drain valve/plug at the bottom of the tank. Open just enough for the water/coolant to come out first. Don’t know if all can separated if emulsified
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 1:07pm
Unfortunately no drain plug on bottom of tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 3:29pm
engine oil will separate from water / antifreeze if allowed to set... Many hydraulic oils are made to hold water in suspension.. they dont seperate... All you can do is slowly suck the good oil off the top or put a long tube and suck the mix off the bottom.... its not going to be pretty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 3:39pm
re: Unfortunately no drain plug on bottom of tank.
OK, I HAVE to ask WHO decided to NOT have a drain plug in an 8,000 GALLON tank ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 4:12pm
That, I have no clue. Tank is probably 30 yrs old. There is an outlet valve on one end, about 6-8 inches up from the bottom, but for a drain plug on the ‘belly’ of the tank there is not.
This page was generated in 0.219 seconds.
