AC 80t
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: AC 80t
    Posted: 07 Sep 2022 at 6:08am
Can anyone give me details of diameter and length of transport rod and where it went for a 80t?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 7:03am
A couple years ago I read a post about the specs on it but I can't find it anymore and I would like to get a replacement for mine...(even if someone has an original 80t, they can measure the length and where it goes for me then I can make my own?)
Thanks Matt
Edited by Hunt4Allis - 08 Sep 2022 at 7:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 7:20am
Would you want an nos rod
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 7:22am
Depends on price and location
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 10:34am
The rod is 54" from the center of the hook to the center of the eye on the bar end.  5/8 diameter.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 11:24am
Ok, so that's the transport position and when you are ready to mow you then obviously have to remove the whole thing including eyebolt from sickle bar and store it somewhere correct?
Edited by Hunt4Allis - 08 Sep 2022 at 11:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 3:28pm
Mounts under the frame.  Haven't tried yet with mine as just use it around the acreage and homestead association common drive.
Photo from a manual I purchased, rod mounted in the middle of the photo.  Extra tab welded at an angle on the sickle side of the axle for the eyelet to bolt through.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 7:02pm
This is labeled 805011
Edited by Mikez - 08 Sep 2022 at 7:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 7:51pm
Close the loop and add some chain, or cut in the middle, and weld in enough straight rod to make up the difference...Wink
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 8:54pm
is that for a 7 or 9 ft bar?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2022 at 8:34am
I'm not sure, it's 36 and the post above it said and shows it being 54 in. I'll have to raise my sickle up and measure
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2022 at 12:03pm
Both 80T mowers I have are 7' bars with the 54" support.  I do have another support bar measuring 43" hook to eyelet - think it came with some spare parts and may be for a 6' bar (?).  The 43" looks similar to the 35" support bar posted.
Found another support bar which came with the second mower which looks different compared to the others.  Only 1/2" bar and 51" hook to eye.  It has a repaired spot as the stop ear on the gear box was clocked in the wrong position and all the stress and weight of the bar kept flexing it until breaking.
Edited by AcFordHawk - 09 Sep 2022 at 12:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2022 at 6:37pm
does anyone have an 80s they could measure. Maybe this is marked wrong.
