7040 axle
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: 7040 axle
    Posted: 05 Sep 2022 at 8:35pm
What is the best and/or easiest way to shorten long axles on a 7040? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 9:08pm
Don't know best or easiest but have seen what looks like acetylene torch work. Kinda ugly but worked. Don't know how hard they are but maybe a portable band saw would work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 9:20pm
Clamp a chop saw to axle and go to cutting.    Use water to keep axle cool. The cooler the metal the better it will cut..                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 9:44pm
The local Case dealer many years ago made an attachment to his chop saw. They would jack up the tractor, put it in low gear and let it idle. The saw operated under its own weight and 20 minutes later the axle chunk would fall off. He never said they used water but that wouldn't be a bad thing.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 7:26am
Went to a tractor show the other day and saw for the first in awhile a 1468 international with its twin exhaust stacks in original paint sitting there. The axles had been freshly cut probably the day before as the cuts were bright steel with no rust yet,but i was horrified as they had been done free hand with a cut off disc,and not even square to axle,and the sharp edge burrs still on.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 7:56am
The cold saw style cut off saw(low rpm carbide blade) is what I've heard work good, as well as the big band saws.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 8:29am
Never realized this was such a frequently done thing!  Dang!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 1:10pm
Probably applied more to used purchases which you don't want to put axle duals on. They are annoying with singles.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 2:01pm
Did that a few times when I worked for a dealership. We set up the band saw to cut em off. Didn't require much babysitting; just turn it on and let it cut.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 2:33pm
Must be dang awful annoying.....and take resale away from anyone who wanted to use the duals.  Oh well, their tractor, their choice, to each their own.  I normally have plenty to do!!! haha
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 4:02pm
I know that one of the customers that we sawed the axles off for was using the tractor as a loader tractor mostly, and had a bunker silo with concrete walls. Long axles would hit the silo walls while scraping along the edge. That was on a case IH magnum tractor
Darrel
