Overhaul kit for AC 170 gas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Overhaul kit for AC 170 gas?
    Posted: 04 Sep 2022 at 9:34pm
Who makes and or sells the best overhaul kit 8:1 compression for AC 170 gas? Thanks, Tracy
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 1:10pm
Only place you can get a stock 4" bore is with original Allis parts.
That being said, my shop offers several different piston/sleeve kits for the 226 'big block' gas engines:
A. Aftermarket 4 1/8" bore 7.25:1 ratio
B. Aftermarket 4 1/8" bore 8.25:1 ratio
C. OEM D17 kit, 4" bore, 7.25:1 ratio
D. OEM 175 kit 4" bore, 8.25:1 ratio
You may have to get a 8.25:1 kit and have 1/16"? machined off the top lip of the piston to get to the 8:1 range.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 7:01pm
Alex, Thanks, PM sent. Tracy
Edited by Tracy Martin TN - 05 Sep 2022 at 7:07pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 8:05am
Check out this topic from a couple months ago.
I don't think there would be any issues using a 8.25:1 175 kit in a 170
Edited by Allis dave - 06 Sep 2022 at 8:08am
