WC Starter and Distributor Points
jshoemaker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jshoemaker Quote  Post ReplyReply Direct Link To This Post Topic: WC Starter and Distributor Points
    Posted: 03 Oct 2010 at 9:53pm
Will the WC Starter and Distibutor Points work off 6 or 12 volts?  I know the generator will be one or the other, but I was told the starter would run fine off either, is that correct?
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 10:02pm
I have my Dad's WD45 that was converted to 12v without changing the starter over forty years ago.  It has an alternator and a resistor mounted just before the coil.  You don't want to keep grinding on the starter if it doesn't start right away.
Edited by JW in MO - 03 Oct 2010 at 10:07pm
Sheridan-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheridan-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 10:04pm
The starter dosent care if is 12 or 6 volts.  I run 12 volts on all my tractors.  I dont know about distriutor points,
HANSEN'S OLD ORANGE IRON
We show, pull, & go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 8:16am
Starter doesn't care on voltage nor on polarity. Points dont care , nor does the distributor.
Coil does and needs to be 6V or 12V and polarity has to be right to tractor polarity.
Using a 12V on ignition without a resistor either external or internal will shorten point life and cause failure of contact or point arm overheating and bending.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
