1968 D10 Overheating |
Post Reply ![]() |
KD8NGV ![]() Bronze Level ![]() ![]() Joined: 03 Oct 2010 Location: Ohio Points: 178 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Oct 2010 at 9:29pm |
Hello all!
I own a 1968 Allis Chalmers D 10 Series 3. I recenty have been having problems with her overheating on me. I went to a plow days and she ran fine. I replaced the points, condensor and rotor. Had this tuned up and she ran fine. Then about 2 months later I took her to a show in Crawford Ohio. I went in the parade and the temperature hit 225 degrees. I obviously stopped and let her cool down. Thinking it was a minor fluck I added some water and went to the next show. She overheated again. I then replaced the thermostat ( a 190 opening ) with a 160 opening. She still overheated. When I bougt the next thermostat I flushed the system ran her with out a thermo and she ran about 180 for about 20 minutes. I then put the new thermostat in and she heated up again. I talked to a buddy and he noticed that my Fan blade/Water pump bearings were going out ant thus my problem. I bought a replacement (new) pump and installed it. I flushed the system and put in a 3rd thermostat (160). I took her to another parade and show later in the fall and she did not "overheat" and lose power, but ran abotu 215. I know they are supposed to run at 190 or less. The radiator is newly replaced 3 years ago. Many thermostats ( ones from napa) and a water pump were put in as well. I flusehd it many times and run a rough 50/50 mix. The bypass works. I took a laser thermometer to the lead of the temp guage and it measured accurate within 5 degrees. I have about ran out of ideas of what it wrong. Any help or hints would be great!!! I have posted on here ( the old site ) many times and have had great luck, you all are a good group. If you have any questions about what I have, or have done please ask!! Thanks again, Kevin
Edited by KD8NGV - 03 Oct 2010 at 9:29pm |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7489 |
Couple of things to check out...
Exact 50/50 water antifreeze mixture is best - too much antifreeze will make it run hot.
Your rad has been flushed, but has the dust and dirt been blown out of the fins?
Might also want to check out your rad cap.
firebrick43 ![]() Orange Level ![]() Joined: 10 Dec 2009 Location: Warren County Points: 592 |
Do the thermostats have a hole drilled in them?
Firebrick43: Yes my thermostat does have two holes drilled in it. That way if it comes out of its "holder" it will allow the bypass to flow water thru. I would say it is about 1/16 to 1/8 in size.
DSeries 4: The dust and dirt has been blown out. There really was none in there. I can see through all of the fins perfectly. The radiator cap is original to the tractor ( I think. It has less than 650 hrs) The seal is good and the spring is strong. |
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Kevin, it sounds like you are doing all the right things.....though I do wonder about that radiator cap. I know zip about D10's but I imagine it wants to run a pressurized cooling system - just maybe that cap that looks okay isn't. Good luck - and welcome to the Forum!
WC, CA, D14, WD45
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
I have seen situations where a defective radiator cap has caused overheating, but I doubt that is the case here. If it still runs hot, I would make sure that the water is able to flow and the fan belt is tight and not slipping. My CA doesn't have a thermostat in it (I just use the shutters) and I can see the water circulate with the cap off. If you can see the water circulate at a good clip too, I'd be thinking leaking head gasket or maybe a cracked head. You could look under the valve cover. If there is plenty of milky looking "snot" on the cover, good chance the head gasket is leaking.
Larry Miller ![]() Orange Level ![]() ![]() Joined: 21 Nov 2009 Location: NWIL Points: 909 |
I have a D 10 that overheated without all the problems you describe. Flushed several times with no help. The radiator was just too plugged up and would not flush out the crap. Maybe a cheaper fix but I put on a new radiator and problem was solved.
I used to be young and stupid, now I am not young anymore.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10753 |
Engine timing and fuel mix ratio can cause overheating. HTH Tracy Martin
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1324 |
Sounds like you did make sure to verify it is really hot with a separate temp probe. I chased a problem on my daughters car for a month and found it was a dash circuit problem, the engine was not really overheating.
I missed that when I read your post before. Edited by Rick of HopeIN - 04 Oct 2010 at 8:33pm |
To Dave: Thanks, and I am glad to have joined the forum. I have posted in the old one before, however this is my first in this new one.
To Tracy: This was the cause! I had it running way too lean. I adjusted it and it went back to running a consistent 180! To All: Thanks for all of your suggestions! They all helped em solve this problem!! Thanks, Kevin |
Post Reply ![]() |
