parts for sale
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Topic: parts for sale
    Posted: 30 Aug 2022 at 10:48am
USED PARTS FOR HD5,HD6.HD7,HD9,HD11
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2022 at 9:38am
Would you happen to have a dozer valve I could incorporate into my valve stack in my 11B? I have a dozer blade with tilt but no ripper. Would like to consider installing a hydraulic drag winch on the back of the tractor for skidding logs.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2022 at 2:27pm
I check monday if am still have a hydrolic valve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 6:28am
Any luck locating a valve?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:15pm
HI  I have a complet valve who was instsled on HD11G-C  with 3 valve spool and she is GRESSEN MINNIAPOLIS part 2-873,7g82
                                             763 166
Projectlb7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Projectlb7 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 4:12pm
I have an allis HD5 with a loader. I am looking for a starter and track pads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 10:42am
HI  I am sorry have no more HD5 startor and track pads .SORRY
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 8:05pm
We used a 39MT starter on an HD5G, works great.
https://www.allischalmers.com/forum/39mt-starter-for-hd5g_topic186931_post1602412.html?KW=starter#1602412
Post Options Post Options   Thanks (0) Thanks(0)   Quote Projectlb7 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 4:02am
I e seen people do that. But I haven't been able to find a counter clockwise starter yet. That's 12v 11tooth. They are hard to come by.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 6:01am
Hmmm... our HD5G has a Detroit Diesel 2-71 which uses a clockwise starter; what engine do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 9:01am
                                             763 166
Hi Hector, any chance I could get a photo of that valve stack?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 4:17pm
I do't know how send a picture let me have your cell.phone and my daughter could send picture for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 5:46pm
M42 starter and if it is for a Detroit engine , tooth count is right , direction is right and power is right , all you need is to install a push button as it uses a solonoid pull in rather than hte foot lever .
Jwise5689 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwise5689 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2022 at 8:00pm
Looking for hd6 cylinder head for the 5.6l 4cyl diesel allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2022 at 5:03pm
I check tomorrow if am still have a head for HD6
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2022 at 8:38am
I am sorry have no moore head for HD6
Tirediron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tirediron Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2025 at 9:50am
Hi,
How bout an oil cooler for a HD6? I need one for my m100b grader and it would swap over.
Thanks.
Tanman67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tanman67 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 6:54pm
Hi, do you have any more HD5 parts? Looking for headlights engine panels with the louvers and the lower panels that bolt below those and then as well as a seat and armrest otherwise I will make some and have an Upholstery guy make them.
This page was generated in 0.112 seconds.
