Allis Chalmers Model G Tractor - $1,200
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers Model G Tractor - $1,200
    Posted: 29 Aug 2022 at 11:09am
The History:
It has been sitting in a shed since 1998 and quite possible longer than that!
Unknown history before that
Look at the pictures in order and read the text
I wired brushed serial number (G23960) and installed new shifter boot since it will be outside for photos and it been raining every day.
All items are there, it’s a complete tractor.
Thieving cousin stole some parts but I have purchased replacements and will be included in the sale.
Has Master Toolbar & Master Lift with all parts and it works
Has snowplow or manure scraper
Has decent tires on back and mismatched fronts – all hold air
Thieving cousin stole seat pan & seat spring – I have purchased a replacement seat spring – you will need to find a seat pan.
Starter & generator are there
Here is the BAD part, it looks like something was bolted to clutch housing and broke a chunk out, I am in the process of bidding on a replacement clutch housing and whatever I pay will be what you pay, IT WILL NOT BE INCLUDED IN THE SALE, it will be an extra cost item, if you want it.
Missing hand crank & hand crank casting – these are being reproduced
Carburetor is there and distributor – thieving cousin stole air cleaner tube but I purchased another one and will be included with the sale.
Intake/exhaust manifold is rusted thru and at some point someone tried to patch – these are being reproduced
I didn’t try to start because of manifold issue, that will be for new owner, but the motor turns over because while being towed I put into gear but the transmission lube leaked out because of missing PTO cover so I quit.
Thieving cousin stole either the PTO or the plate that covers the hole – you will need to decide what you want to do there – I don’t have a PTO or the plate.
Radiator  looks like crap but has had water it there for over 2 weeks and hasn’t went down.
Missing taillight – these are being reproduced
So that it, basically a complete tractor that needs some loving!
Edited by JCSinPITTS,PA - 29 Aug 2022 at 11:18am
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 7:45pm
I sure wish you were closer Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 7:56pm
Hmmm...... that's interesting. A trailer ball mounted up front. Musta' been used for moving trailers, boats or sometihin' around....Great resto project for someone.
Steve@B&B
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2022 at 2:10pm
Yes, Steve I noticed that ball, different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2022 at 8:28pm
