Allis 175 Diesel
xr4ticlone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xr4ticlone Quote  Post ReplyReply Direct Link To This Post Topic: Allis 175 Diesel
    Posted: 28 Aug 2022 at 11:11pm
Bought this tractor a year or so ago. Mainly to mow, but have a 14' disk as well. Haven't used it a ton, my kids mainly run it.
Couple things...it's not leaking anywhere I can see, but it always seems short on hydraulic & transmission fluid.
The bigger issue is (the clutch works great) but when disking today it would just stop.  I could put it in another gear and then run it for 10 or so minutes...then it would once again just stop.  NOT popping out of gear...just not moving.
I'd checked the oil level in the transmission and hydraulics.  Running just standard hy-tran tractor oil.
Anyone seen anything like this before?
Thanks in advance.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 11:19pm
Power Director may be slipping, try it in both low & high with disc see if it does it in both or just 1.
 Hydraulic / transmission fluid does not evaporate very fast so if both get low you have 2 leaks. Find a clean bare place to park it after use. You'll have oily spots on the ground after its left parked overnight after use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote xr4ticlone Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 11:59pm
Ok...I'll check.
It doesn't leak.  I was parked on the concrete for 3 weeks while I got the seat situation fixed and...nothing.  (Long story...everything here is waiting on something else.  I put external vinyl on an old 8000 series seat an made a mount to put it on the 175.)
I had it in 3rd and it stopped.  Went to 2nd same result. Then had it in 5th then quit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 5:48am
Foot clutch is slipping. Place the PTO in gear and when the tractor stops, I'll bet the PTO is also stopped.  Good chance the clutch pedal has zero free-play.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 7:44am
Do like Dr says, you have to figue out if the foot clutch or the hand clutch is slipping. The PTO will continue to run if even if the power director is slipping
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 7:58am
The chances of a 175 Power Director slipping on BOTH low and high sides is very small, like nearly impossible. It almost sounds like the operators have the Power Director lever in neutral getting by with the "creeping" until the oil gets hot.
Edited by DrAllis - 29 Aug 2022 at 8:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2022 at 7:55am
Waiting for a response on the no-move issue.
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2022 at 6:44pm
What was determined to be the cause of failure?  A lot of us read these posts to solve our own problems.  Don't leave us hanging here
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2022 at 6:54pm
I'm betting the Power Director clutch was never locked fully into either high or low range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2022 at 8:56pm
Or is jumping out. A surprise when it happens and don't look at PD lever                    MACK
