Early 190 turbo needed
JimVH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimVH Quote  Post ReplyReply Direct Link To This Post Topic: Early 190 turbo needed
    Posted: 28 Aug 2022 at 6:56am
I have an early 190 that appears to have the serial numbers ground off.  The turbo is shot and would like to replace it.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 8:05am
Early 190s used a Rayjay turbo which is no longer in business.  You will need to switch to an AirResearch T04 turbo - you will need new oil lines as well.
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2022 at 7:17am
I have a good Ray Jay turbo. I will get the numbers from it soon. It was rebuilt and has very little hours on it. Will sell for $200.00.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2022 at 9:25am
It shouldn't be assumed that his "early" 190XT has a Thompson/Rajay turbo. It might have been swapped to an Air-Research 30 or 40 years ago by someone else. It might have had a newer engine installed. Who knows !! LOOK AT THE OLD TURBO AND SEE WHAT BRAND IT IS !!  Not on a tag...the brand is molded into the compressor housing with raised letters.
This page was generated in 0.313 seconds.
