Converting WD to 12 volt
littlemarv View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Converting WD to 12 volt
    Posted: 25 Aug 2022 at 6:31pm
I've been humming and hawing, and putting it off for years, but I finally broke down and put a 12 volt alternator on one of my WDs. It really is pretty easy, a Napa 2134011SW is what I used. $79 at Napa, with a $16 core charge.
Removed the generator. This WD has a 1/2" fan belt. Not sure if that's correct, I thought they were 5/8"?
Drilled out the 5/16" holes in the original mount, to accept some 3/8" ready rod.
I was told, your original pulley will work with this alternator. Shaft size looks the same, not sure about pulley thickness because I didn't have to swap mine.
Got it set up on the bench, and cut the rod to length.
Mocked it up on the tractor. If you redrill the 2 mounting holes about 1" ahead, it fits right in, and the top bracket needs a slight adjustment to line up nicely.
Wired it to the battery. It is supposed to be a one wire alternator, but there is a ground stud, so I ran two wires. that way I am sure of a complete circuit, and don't have to worry about all the different bolts and connections on the ground side.  Put a coat of flat black on it so it doesn't stick out so much.
The whole project took about an hour. Shoulda did this years ago, will definitely be doing my other one in the near future!
Thanks for looking.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2022 at 8:24pm
Clap   Thumbs Up
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2022 at 8:30pm
looks great! Nice work!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2022 at 2:20pm
Oh yes done that to mine years ago, also done CA that way only I used a smaller atlernator on the CA
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2022 at 6:25pm
I converted my 1955 Ferguson TO35 from 6v to 12v and made the tractor so much more reliable. My 6v 1952 AC WD seems to start so far but if it gets ornery I'll switch it over. I used one of the small 12v alternators the 'hot rod guys' use as it's smaller and fits in the frame of the ferguson (the typical Delco models can get hit by the steering drag link going through ditches. The Farmall cub+ guys also use this hot rod alternator because they have to tuck it up under the cowl.
You'll find it's an amazing+ tractor now.
Just a note: if you add silicone dielectric grease at all connections after polishing them up you'll greatly increase the longevity before corrosion gets in there.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 7:37am
I had a WD that had a bigger block put in it. I put a 8 volt battery in it without changing any other electric parts, worked good.
Driverdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 11:00am
...is the WD now negative ground, and what changes were made to accommodate that, or is it still positive ground ?? ...just wondering...
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 11:28am
It's a negative ground. No changes to the starter. It is a magneto ignition, so no changes there. Just install an alternator and a battery.
If you have a distributor, I think you need to install a resistor so the coil only gets 6 volts. But I would just replace the coil with a 12 volt one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 1:22pm
Thank you for that info..I have a WD45 that I am pondering that conversion as the old generator no longer works..
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 2:52pm
Ya might want to consider having the starter rewound for 12v.I recently acquired a CA that is 12v and the starter wasn"t converted and it took out the starter drive shortly after I got it home.The starter is now at B&B circuits being properly rewound for 12v.It's cheaper to do now than after ya take out a drive, starter nose, and or ring gear on the flywheel. 12v just hammers the hell out of those 6v units.Just my thoughts.
BMinor0788 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BMinor0788 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 5:44pm
Ac45dave,
Where did you get a nose cone for your CA starter or didn’t it destroy that? I need one for my CA starter.
Brandon
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 8:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2022 at 7:05pm
Originally posted by BMinor0788 BMinor0788 wrote:
Ac45dave,
Brandon
Brandon, It didn't get the nose housing, just the drive.Guess I was lucky for the most part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BMinor0788 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2022 at 7:59pm
Yeah you’re lucky. I need a new nose cone for mine as the pinch bolt hole is wallered out. I tried the one Steve posted above but it doesn’t line up. I’m looking for a good used 14 Tooth CA starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2022 at 9:03pm
You can take the nose piece and drill a new hole in the proper location.... Two different locations depending on what tractor it was put on.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2022 at 7:20am
Looks good. When I put an alternator on my WD45, I had to make a new bracket. I tried to reuse the original but the belt didn't line up right.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2022 at 1:06pm
