7045/ PTO Issue
Pete upstateNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete upstateNY Quote  Post ReplyReply Direct Link To This Post Topic: 7045/ PTO Issue
    Posted: 18 Aug 2022 at 2:31pm
Hello everyone, I have a 7045 with a PTO issue. I’m looking for a little bit of guidance please. When I engage the lever for the PTO it turns on but the lever will not stay forward or engaged. I am wondering if it is a cable issue or something else that needs to be cleanEd and or adjusted? If I hold the lever forward it stays engaged. Any advice on this issue would be greatly appreciated thank you!
   Same tractor, when going down a hill it slips out of high range on the consul is that a cable adjustment issue or a worn out transmission issue? If anybody knows. Oh one more important thing it is a Power Director. That would be important to know.
Edited by Pete upstateNY - 18 Aug 2022 at 2:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 9:37pm
First thing to do is screw a gauge in test ports on PTO clutch housing on back of tractor. If low, check stand by pressure.                     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete upstateNY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2022 at 6:58am
Excellent, thank you Mack. I will try that this weekend.
This page was generated in 0.219 seconds.
