Found this buried in the shop: |
Post Reply ![]() |
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2458 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Aug 2022 at 10:04pm |
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25146 |
well, does it work?
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
I'm told it does, yes; but I'm the only one that would ever attempt to use it. It was used routinely until they purchased a shop mig in the early 80's.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12185 |
So.....a WELDER that size was buried in your shop? Dang. That's some burying. Our "shop" is bad, but I'm pretty sure there's no welder buried in it!!!
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8354 |
Thats neat ! Thanks for the pic
It's not that physically large really and easily fits under a workbench where it was since probably the late 90's. The owner long forgot about it and the next generation had never seen it.....
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87819 |
Dial looks like 120 amps output at 100% DUTY CYCLE... thats impressive ! .. must have a lot of MEAT inside !
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41980 |
Looks like a good supply of hangars also , or as we use to call them gas welding rod supplies for piecing together exhaust systems for cars - Shop where I worked when in high school got uniforms from laundry service and they came on coat hangers - looked at it as new supply of welding rod with every delivery .
I do the same Coke. Long lost count of 1/4's and door skins I've welded on when younger.
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4732 |
Since Allis Chalmers had a electrical division did they build this welder or at least design and have the parts made to their specifications?
I'll ask as I wouldn't have any knowledge. I've had A-C motors in the past on air compressors and such but had never seen a welder prior to this one.
It does state "distributed by" however? Edited by Codger - 18 Aug 2022 at 12:26pm |
Mostly all this stuff was made by others and just put the Allis name on them
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10781 |
Favors a Hobart. Tracy
Post Reply ![]() |
