AC D14 OEM Battery Cables
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: AC D14 OEM Battery Cables
    Posted: 05 Aug 2022 at 2:37pm
Afternoon AC Team!  Anyone know for sure if the AC D14 Tractors were originally equipped with 6 gauge battery cables.   My old D14 needs some attention on the battery cables and am looking to replace them with the diameter wire that was original equipment.
I just replaced cables on the 715 loader backhoe and those had 1/0 cable. Am thinking the 6 gauge copper is too small.
Thanks in Advance for any guidance/input!
Respectfully ~ Orangeman
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 3:04pm
I use 2/0 copper cable for all 6V
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 4:19pm
6 gauge is too small.......... 2 gauge is OK for 12 volts... if you have 6 volts, you need bigger.
Edited by steve(ill) - 05 Aug 2022 at 4:24pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 8:33pm
When it comes to battery cables, I always go bigger.
For a 6 volt, go much bigger.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 9:23pm
I like using heavy welding cable when I make any cables. They are more flexible and I think the finer strands carry the current load better
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2022 at 8:26am
Thank you all for the excellent input.  The tractor has been converted to 12 volt and has a GM alternator on it.  ~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2022 at 10:15pm
Over doing it for sure but I use 1/0 regardless if 6 or 12v. Starter spins over so much faster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2022 at 8:17am
Just to close this topic out - I went with 1/0 cables from this place.
https://www.batterycablesusa.com/checkout_one.asp ; I have no affiliation with them but will note the service is excellent and the website is easy to use and intuitive.
Thanks much to all the AC Team contributors and folks that responded.  ~ Respectfully,
Orangeman
Edited by orangeman - 08 Aug 2022 at 8:18am
