D14 options...Question?
Eddie(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie(IL) Quote  Post ReplyReply Direct Link To This Post Topic: D14 options...Question?
    Posted: 02 Oct 2010 at 12:37pm
  I recently aquired a 1959 model D14, and it is optioned with the "Orchard" exhaust manifold. My question is...were these only offered with the orchard versions, or could you special order one  for certain uses. It's been repainted and I don't see any signs of where the orchard sheet metal might have been mounted. It's actually quieter than the vertical style exhaust.  Any info would be appreciated. Thanks, Eddie    Here's pics...
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 1:00pm
Mite hae been a "low clearance" issue when it was bought new? Low barn door or etc.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 5:21pm
I know that the low clearance muffler and hood cover were avalible in the D14 parts catalog
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 6:56pm
I appreciate the nice pictures of the setup. I'd like to put one on due to my 'low door' issue but it might hit the Delco CS-130 alternator I just put on.Could be a nice Winter project though.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 7:37pm
low clearance muffler in 1959 was  #283646 $21.20
over to the front wheel weight post, 93 # $18.30 each
Is utility shielding equipment option meaning  Orchard ?
painting, any color other than standard    $16.90
Edited by bigfish_Oh - 02 Oct 2010 at 7:39pm
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 7:38am
  Thanks for the replies.   When the previous owner tried to explain to me about the exhaust over the phone,  I really expected to find some kind of homemade conglomeration, if you know what I mean!  At first sight it looks odd not seeing the vertical muffler, but it's a nice view from the seat, and no more worrying about garage clearance.  This also has a full length heat sheild inside the hood panel that attaches to the bolts for the exhaust hole cover, and another bracket off the manifold heat sheild, that elbows over to the valve cover. here's some extra pics.  Thanks again, Eddie
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 8:17am
Interesting -- always learning stuff. Nice looking D-14 - and unique.
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 5:40pm
Eddie, Could you post another picture of you rear wheel weights. Are they the 161 and 162 f & H weights?
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 6:43pm
That is a neat option.  I had see one on D10/D12 that made a sharp U turn down.
I need to learn more about D14s, I should be the proud owner of one tomorrow.
Edited by Rick of HopeIN - 03 Oct 2010 at 6:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 6:59pm
If you could get rid of the air breather pipe, then you would only have the steering wheel and your head to snag on low hanging branches or garage doors.  LOL Pretty straight looking tractor there Eddie, nice find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 7:37pm
  The rear weights are 161's. I've used these on 17's before, but never on the smaller tractors. i think they look pretty good on it. This is a solid little machine. The tranny is fine and the finals aren't noisy. The previous owner just had a new clutch installed, and the rear lift cylinder was rebuilt and the hyd. hose replaced. I modified it just a touch, by putting a dash panel from a D15 on it.
