180 Allis Puller
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: 180 Allis Puller
    Posted: 01 Aug 2022 at 6:39am
Hi all. What are your thoughts on the reliability of a 180 transmission and rear end for a 7000lb mod farm class? Estimated hp will be 300 to 400hp. 18.4 x 38. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 7:53am
Transmission strength will not be any problem. People grinding them into gear wears off the shifting dogs, so they need to be in good shape or it might jump out of gear under heavy load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 11:26am
Thanks Dr! Was a bit concerned about the two pinion rear end, but it should be ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 3:50pm
Overfill the transmission a couple three gallons of oil to flood the differential gears. When you get 24.5 tires and more than 500 HP you'll need to needle the diff pin gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 5:10pm
Thanks again, Dr.
