GM 71 series rotor puller
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: GM 71 series rotor puller
    Posted: 31 Jul 2022 at 9:54am
https://spokane.craigslist.org/tls/d/spokane-vintage-gm-71-series-rotor/7514409224.html
I saw this item on Craigslist; my knowledge of Detroit Diesels being very limited I take it that this puller will NOT work on a 2-71. If it did, however, I would probably buy it 'just in case'.
Any inputs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 8:18am
I was hoping that someone would chime in saying "Oh, that will work fine on a 2-71" or somesuch; since it appears that no one else knows for sure either I will just give this one a pass :-)
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 9:23am
Seems it will work on any 71 series blower - but then it's not that often one needs  to pull gear to replace bearings or seals .
 i replaced one lobe in a 2-71 blower and used no special tools . Was told they had to be replaced as set - but shop I got lobe from said the just be sure timing was right so no clash between replacement and present unit .
  previous owner had plugged drain hole in bottom of housing and water got in and froze breaking lobe - which then locked engine - bought machine at good price and repair was not expensive - just time - and ended up selling the HD5B 4 years later
