Early G Lift Parts - ID?
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Early G Lift Parts - ID?
    Posted: 02 Oct 2010 at 10:29am
A fellow had an item on eBay recently - it was a couple of items that he described as Part # 316271 - Lever Handle Clip.  I agree that that is one of the items in the picture but what about the other item?  I can't see where or how it is associated with the early version of the Model G Master Lift at all.  Am I missing something?
Scott(GA)
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 1:42pm
Is the other piece threaded? It looks like the nut for the rod that holds my sickle up in the air when not in use.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 2:30pm
There are 2 of the same part.  One is laid flat, the other leaned up against it to show a side view.  I was the seller, that's how I know.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 2:37pm
Another AC mystery SOLVED!
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 3:24pm
Ha!
That explains that!  At first I thought it was the Lever Handle itself but I looked at one (lever handle) from G112 and that didn't work.  Never even stopped to consider it was the same piece on edge.
Best regards,
Scott(GA)
