Gleaner transmissions |
Post Reply ![]() |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7518 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Jul 2022 at 1:30pm |
Can anyone tell me which other transmissions are interchangeable with one in an E3 combine? I am pretty sure the K is. Would the F be the same?
Asking for a neighbor. Thanks! |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22071 |
No way an "F". Probably a K.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3573 |
DseriesIV, probably all older model Es & all early model Ks(1969-1977). Should check part number though?? I can check later when I’m back in my office.
Later 7-25-22 Edit/update:The older E trans’ beam/tube assy MOUNTINGS differs from EIII/K/K2 models. The E’s trans mountings are positioned on top of their trans. The EIII/K/K2’s trans mountings are positioned on front of their trans. Hence the difference in their CASE trans part#s as follows. E parts catalog, May 1967 shows following; Case, trans 71131408(prior trans 3-63-0001). Case, trans 71131690(Eff. Trans 3-63-0001&up). EIII/K parts catalog,Sept 1972 shows following; E3 & K trans case assy part# is 71151727. K trans shafts,axle drives differ @ sn18601.(may or may not affect, trans swap??) EIII/K trans clutch bell housing part# 71145047. 71141628-beam asy,axle(EIII;prior an K 5001).May or may not affect swap? 71153760-beam asy,axle(Eff. An K 5001-8201). May or may not affect swap? K2/F2 parts catalog, Oct 1978 shows following; K2 trans case assy part# 71151727 (same as EIII/K). Note; the 71151727 EIII/K/K2 transmissions should readily interchange. The E will not readily interchange to EIII/K/K2s without at least beam/tube fabrications. While doing a 71151727 trans swap, take the opportunity to RE-SEAL drive shaft SEALS (2 - Left & Right sides, part# 71145028) on usable trans before re-installing it. Edited by AC7060IL - 26 Jul 2022 at 12:51am |
My neighbor just bought a K that has been sitting many years. Looks to be an older one, so hopefully the transmission will fit the E3 without any major problems.
fjdrill ![]() Silver Level Access ![]() Joined: 13 May 2012 Location: Alabama Points: 392 |
Early k and E3 the same. I went to south central MS and cut up a K for parts. I salvaged everything except engine for my E3.
Back to top because of edits/updates
Post Reply ![]() |
