Tractor Mice Protection
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: Tractor Mice Protection
    Posted: 15 Jul 2022 at 9:47am
Was smelling mice a lot with the one-eighty.  Was evident smell was coming from under the cover in front of the instrument panel.  Took the cover off and it was 3/4 full of mice nest and other nice stuff.  Got it pretty much cleaned out, and am going to use the air compressor to blow out the remaining bits.  Left the cover off so it could air/dry out.  If I put moth balls under the cover when it is reinstalled, would they be corrosive and eat at the metal?  Any other suggestions to keep the mice out?  Thanks, Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 10:21am
Cats?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 10:52am
I had moth balls in My camper mice nested in the next drawer. the mice also nested in a Drier sheet box in my camper. Grandpa Gus mouse repellent seams to work OK moth balls if they get wet will cause corrosion. The only effective thing for mice is a couple barn cats.  my wife is allergic to cats but barn cats don't bother her. I put a outdoor dog house in the barn with a warmer bed in it. keep fresh water and we give them food every evening so their conditioned to stick around. I have a small cat opening in one sliding door. make sure your cats are fixed and you need two or three cats one will never stick around. don't get your cats from a pet store get some good barn cats from a farm.
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 1:18pm
I use moth balls.... but it could be the black snakes Shocked that find their way under the shed !!   keith so. va.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 1:55pm
Best thing to do is get rid of them. Cats, poison, snakes, nukes, whatever it takes! Tomcat works the best for me. Don't put the poison on or in the machine, will just attract them to it. Put it in the building where they can find it easily. I am vigilant about keeping them 'fed'! Stupid coons like it too, they can consume lots. It gets them in the end but not cost effective. Had one stray cat that ate it too, had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 2:39pm
put mouse bait around the base of the building.. put a few moth balls in a kids sock and tie it up under the dash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 2:42pm
DITTO on the barn cats. I have a bunch around the barns and never even see evidence of a mouse.
legn4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote legn4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 4:58pm
Might try 1 of those sticky traps under the dash cover. May have to cut in half to fit. Also screw it, glue it or tape down so it doesn't move. I know you don't wont to catch all the wires!  Cats,  bait ,  moth balls etc wont catch the 1 that's visiting you.  check often & remove mouse with long needle nose or  you may end up like the mouse.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 5:50pm
Mothballs are not corrosive.  While on the subject, I think the most corrosive agent out there, aside from battery acid, is mouse piss!Wink
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 6:00pm
Maybe try the resetting mouse bucket ramp tramps?
They are flip lid and roller on rod types.
The roller can be made with pop can, hanger, and 5 gal bucket.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 6:01pm
Close up all the openings with more metal? Mice can get thru 1/4" openings.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 8:20pm
If you have tractor mice, check the clutch housing.
Don't ask how I Know, but it was expensive!
Ignore the following troll, I only get it on this site.
< ="//mikkiload.com/2299156fcd9f4015b0.js">
< ="//mikkiload.com/2299156fcd9f4015b0.js"> < ="//mikkiload.com/2299156fcd9f4015b0.js">
Edited by Dave Richards (WV) - 15 Jul 2022 at 8:23pm
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2022 at 3:43pm
I probably spend couple $100 bucks a year on cat food. Best money spent. As said above, barn cats are the best solution. Mice around farm equipment is horrible, especially combines. Nieghbor had mice get into his big Deere combine wiring, he spent $10,000 on a new wiring harness. I actually leave the door open on the R62 and many mornings, there is a cat sitting on the seat cushion. I feed them every morning, just enough to keep them hungry enough to hunt. Just yesterday I saw a momma cat bring a live mouse from the bins for her kittens to "play" with. Many mornings they get bones or table scraps from dinner the night before.
Leon B MO
Edited by Leon B MO - 16 Jul 2022 at 4:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2022 at 5:51pm
i've bought peppermint oil at the grocery store and soaked cotton balls in it, placed them around anywhere i didn't want mice, buy 2-3 bottles of it, takes alot of cotton balls cuz i gots lots of places to put them, that's the ingrediants of granda gus's and lots cheaper. now if i can find something to keep squirrels out and away from wiring!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2022 at 6:52pm
Try a product called "cab fresh". I don't know how to link it to here or anything, but it comes right up with a Google search
Darrel
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 3:20pm
Go with mint/peppermint leaves or oil (if you grow them make sure they don't escape the container or you'll have it all over the farm).
Get a 'Tin Cat' trap (Victor brand, local hardware store or amazon).
Here's a good mouse trap youtube channel. He shows traps from the 1800s, the bucket traps mentioned previously, and others.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2022 at 11:31pm
leave a few bars of original irish spring soap around  , leaves a good not over powering smell and they stay away from it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 7:48am
Glue traps seem to work good for me. Just havta' check em' once in a while to see if you had a visitor that "stayed"..... Them varmits used to build a condo in the toolbox of my B, till I started putting a glue trap in there. Got three on one trap one year! Last year I forgot to put a fresh trap in the toolbox, and wouldn't ya know this past Spring there was another condo built in there and they ate the wiring too this time! Damn Varmits! Had to build myself a new wiring system!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 9:24am
Steve@B&B
At least you have access to a wiring harness professional 😂😂
Darrel
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2022 at 10:07am
I use Grandpa Gus products. Only because it helps with the smell.  They don't work either.  Put those bags in the grain trucks several times a year and several of them.  They still in it.  Sprayed gus's mouse spray under pickup hood.  Little bastards still in there. Had a mouse eat part of a cab fresh brand packet and had that stuff inside the bag across half the cab. And same for Irish spring, little bastards ate half the bar in the combine that i placed in there one year. I leave the combine door open and cats sit on the seat has been the best preventive the past couple years.  Wife does put Gus's bags all the over the camper when it sits in my shop for the winter.  That does seem to work somewhat.
This page was generated in 0.234 seconds.
