3500 l2 pump timing
mike-mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike-mn Quote  Post ReplyReply Direct Link To This Post Topic: 3500 l2 pump timing
    Posted: 12 Jul 2022 at 9:06am
I just had the pump redone and looked at the timing marks and it was 14 degrees btc.  Is this right?  I put it in my 8050 and it was running hot according to the guage baling hay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2022 at 8:23pm
Not knowing the model year or any numbers off your injection pump, I'd guess 16 degrees BTDC is correct for a DM-4 Stanadyne.
Edited by DrAllis - 12 Jul 2022 at 8:43pm
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2022 at 10:03am
Was it a late L2 with AMBAC 100 pump?  if so then it would need to be timed at 18 to 19 degrees BTDC.
