G manifold
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Topic: G manifold
    Posted: 12 Jul 2022 at 2:54am
Hi all is there anyway of cutting new threads for the muffler in a G manifold or do I need a new one.
Tractors Allis EB,two C,diesel G
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2022 at 5:30am
You can try to tap new threads in.   When I had a shop do that with my D17 manifold, the tap split the top of the manifold.
AaronSEIA
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2022 at 9:48am
By "cutting new threads", do you mean the old threads are stripped out ?
If so, is there enough (cast) material to re-thread?  Might try tapping it anew as Aaron said.  OR, does it require going to the next size NPT?
Then something else to consider.... If there's a machine shop in your area that has a CNC mill with a threading cycle.  Ask them if they can do it.  Shouldn't be too much of a challenge.
Of course, both these suggestions assume there's material there.
