28in tires on D-15
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Topic: 28in tires on D-15
    Posted: 05 Jul 2022 at 4:17pm
Will 14.9 x 28 tires fit ona D 15.  It now has 26.  I know I would have to find 28 in rims.  Thanks
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 4:51pm
I've 13.6x28" tires on mine, you may not be able to have tires in narrowest width setting as tire may contact fenders.
 You'll need to find 28" centers, 12 or 13"x 28"rims and the tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 5:27pm
Consider your drawbar will be higher, the PTO shaft will be higher and every transmission selection will be faster. If none of these affect how you use your tractor, then go for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 5:43pm
original were 12.4 x 26 ........... going up to 14.9 x 28 will be a LOT TALLER... If thats what you have , OK... if your buying, look for thinner ( 12.4) tires.
