carpet or vinyl,,,? |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13761 |
Topic: carpet or vinyl,,,?Posted: 03 Jul 2022 at 6:04am |
Well, the 20 year old carpet in living room and dining room has to get replaced and since the boys will one day inherit the place, I have left it up to them to decide on material used for replacement,,,(including the cost, heh, heh,heh) I was kinda leaning for the newer vinyl that is quite a bit thicker than the vinyl or rather linoleum of years past. The vinyl I looked at in Lowes is bout 1/8" thick and am told is very durable,,,? The boys are not interested in carpet and neither am I. The other possibility is the 8" X 48" ,,"Click" panels that "click" together with a light hammer nudge,,,,, I got some quotes of $2,500 for the vinyl and $5,200 for the "click" panels. (Quotes are labor and material) There is lots of Labor costs with the Click flooring and the Handiman I trade work with tells me he can lay the click flooring but does NOT want to tackle the Vinyl installation. Anyone got any comments?
B26240
Posted: 03 Jul 2022 at 6:24am |
Carpet is out in my book, the cheep on sale click flooring is usually a PITA to install. I have a better grade click plank flooring in our hose for at least 15 years and it is holding up great, cat can run around spinning his wheels and no sign of scratches. The rolled vinal has many choices price/quality I did both of our bathrooms with mid price brand from menards last winter, small areas easy to install simple to replace if it goes bad so far its ok but hasn't been six months yet.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25160 |
Posted: 03 Jul 2022 at 6:43am |
BOTH are a PITA !! You have to remove EVERYTHING outta the rooms then vacuum the floors really,really good. My 'vote' is for a higher end 'click panel' floor just be SURE to BUY an extra box of the planks !!! If (...when...) a section gets damaged, you'll have the correct planks to repair the floor. Just be sure you know which closet you stored them in !! Also buy the 'installation kit' the plank mfr sells. It has the CORRECT sized 'fitting piece',so NO damage to the planks. Normally you install parallel to the longest dimension. If room is 10 by 12, planks run 12' long.If there's doors between LR and DR, there's a 6-8" 'strip' to look like the 'threshold' of the doorway.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 03 Jul 2022 at 6:44am |
There is very good and very bad and in between laminate and vinyl snap together flooring.
We haven’t used any rolled vinyl at work in years. Cheap will buckle and squeak and feel like soft spots. We put wood look ceramic tile in our kitchen living room and main hall and laundry. If I had my way that wouldn’t be. |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35536 |
Posted: 03 Jul 2022 at 7:01am |
We caught Plank flooring on sale at Lowes a few years back, required a underlay 'pad' or insulation laid and taped down but not hard for even myself as a one man show to lay. are several trade trick videos so do not end up with a 1" last lay piece at the end run on YT.
Ours was 3' lengths so had option of 1' staggers or as I laid it simple half length offset stagger, saw where one had been herringbone laid but I am NOWHERE to near a flooring layer to do that. Just remember to as noted pickup a extra box or two, then the threshold or transitions strips and floor attaching hardware. Had ours done in four days work, three rooms two alcove halls and main room flooring. I opted to lay ours before I put baseboards on but with the trim in place adding a 1/4 cove or 1/4 round is a good finish touch. Feels good underfoot and wears awesome so far, ours is a 'Water Resistant'. I decided on Half Lap so to limit End Cuts but now do not see as gained much. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5266 |
Posted: 03 Jul 2022 at 7:14am |
I'd go with quality hardwood. It will outlast the kids and also the grandkids. What ever you do on the cheap will be just that CHEAP.
iowallis
Joined: 04 Jun 2017 Location: North Iowa Points: 386 |
Posted: 03 Jul 2022 at 8:08am |
Considering it is your living room and not a kitchen or bath I would go with carpet. You put down hard surface flooring then a throw rug on top as it is "too hard" for comfort to walk on with bare feet. Then when you are somewhat older the home heath aid tells you to get rid of the rug as it is a tripping hazard. One of my rental houses has commercial grade carpet (tight/short weave) in the area from the living room down the hall to the bedrooms. 20+ years old and no obvious signs of a wear pattern.
This is in a pet free house, if you have pets that may have accidents that would change my mind to go with hard surface flooring.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90498 |
Posted: 03 Jul 2022 at 8:38am |
I put ceramic wood looking panels in our living/ dining/ kitchen... on a concrete slab. Daughter has a stick built house and we put the wood plank manufactured flooring in her first level a few years ago.. They have dogs and it works out great. Son has hard wood oak in his house.. Looks good, but way to expensive.. Carpets if for the bedroom only.
dee_veloper
Posted: 03 Jul 2022 at 10:37am |
I'd go with carpeting. Helps deaden noise levels. More comfortable to walk on and better against slipping, an important factor as we get older.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
DMiller
Posted: 03 Jul 2022 at 10:42am |
1966 we moved to a new house in St. Charles MO, Brothers trying to be nice took shoes off in Kitchen as had Hardwood floors. One brother was upstairs and got called down, socked foot slip on slick hardwood steps, tumbled down steps. Two months later Pop had the Carpet people back to carpet stair treads at center, then Pop was running late came down steps in his Oxfords, leather soles, slipped on carpet and busted his behind!! Carpet can be just as slick as hardwood, do not let that change your mind.
dee_veloper
Posted: 03 Jul 2022 at 12:20pm |
Wearing smooth, leather-soled shoes is like driving on bald tires.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6601 |
Posted: 03 Jul 2022 at 2:56pm |
A good grade of LVP (luxury vinyl plank) would be my choice, durable and easy to install. Second choice would be laminate (click) flooring. I put laminate in my house and LVP in my daughter's house.
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 03 Jul 2022 at 6:08pm |
I vote for a good quality 'click' vinyl plank or tiles. They are extremely durable and the thicker planks will have a cushioning on the bottom that makes them quieter and feels softer. Quick to install and easy to clean.
shameless dude
Posted: 03 Jul 2022 at 8:12pm |
we have carpet in our kitchen and in the bathroom, is lots warmer in the winter, and X2 what Dee says! one of the stockholders also had carpet in their kitchen, when they went to sell the house their best friend realtor said they would get a better price if they put a hardwood floor in the kitchen instead of the carpet. their house sold, for less than they were wanting after they spent almost $4000. for the new kitchen floor! the new owners put new carpet in the kitchen over the new hardwood floor! LMAO!!! i use the hardwood floor boards for walls around here! the inside of the cook shack is also getting the hard wood floor boards on its walls. so far it looks great! let the kids do what they want when they get it.
desertjoe
Posted: 03 Jul 2022 at 10:06pm |
Altho, the quotes for the vinyl flooring are much cheaper than the planks, I have just about talked the boys against it as any repairs later would be very costly, plus the one Grandchild is a terror in and out of the house and always dropping Chit on floor. I also have the Wife's two Yorkies that will sometime piss in the corner when I don't get up fast enough when they call,,,, ![]() ![]() I am reading ya'lls suggestions and seems to be two kinds of "Plank Flooring,,the vinyl planks and the "Click" flooring panels,,I see where it comes in several widths and lengths, and so far, Lowes has much better prices than Home Depot or McCoys Lumber. Wondering WHY the different lengths and widths?? I have measured and measured again and it is going to take 489 Square feet of material for the dining room area and the living room so am looking at 500 Sq feet.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8387 |
Posted: 04 Jul 2022 at 12:14am |
Joe, I imagine your house is either on a cement slab, or pier & beam? Our house we have now is pier & beam, previous owner put down the flooring that is some type of sticky on the back, in strips kinda imitation laminate in most of the rooms. The main living/family room was untouched exposing the original hardwood floor.
Our previous house was on a slab, with all the bedrooms and dens carpeted. Kitchen and dining room were vinyl. My sons house is also on a slab, previous owner had 100% tile, high grade tile and grout. Looks beautiful, easy to clean. But in the winter those floors are cold as all get out, especially the closer to outside walls you get, the colder your feet become. We have gotten area rugs to use, but be sure they have a rubber/foam backing to reduce sliding. |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11379 |
Posted: 04 Jul 2022 at 2:38pm |
our whole house is the click together and we love it. I layed it 15 years ago when I built the house and it is wearing great, except where my wife wouldn't wait till I moved a box of meat and she slid it across and broke off a corner on one plank.
shameless dude
Posted: 04 Jul 2022 at 5:42pm |
just pour another layer of concrete and have them throw some color powder in it!
jaybmiller
Posted: 04 Jul 2022 at 8:29pm |
Hay Dj.. since the boys will be getting it, let them decide....!!! then after you buy the materials, get THEM to install it......hehehe oh look..... there's a pig flying overhead being head up by lead balloons......
desertjoe
Posted: 07 Jul 2022 at 11:40am |
Well,,it sure lookin like it will be the tile for both rooms as I fount a whole chitload of some new ceramic tile thaat was left over from a BFJ down in C-bad at a dang good price. Just happens to be the 18" X 18" in the pattern and color they wanted,,,, ![]() ![]() Only'ist thing is the guy I trade mechanic work for carpenter work with has suggested I install some of underlayment vaapor barrier stuff. I checked Lowes and they have bout 8 different types,,,,,?? Any comments from experience,,,??
DMiller
Posted: 07 Jul 2022 at 11:53am |
If direct to concrete do the pink paint on sealer
If on subfloor then go with 1/2” Durock with grout to the floor and tile compound to the durock for time layout |
tadams(OH)
Posted: 07 Jul 2022 at 1:51pm |
If it's cement floors go naturestone and be done with it for ever. We love ours in our family room.
GSTROM99
Joined: 12 Dec 2020 Location: Greene, IA Points: 246 |
Posted: 08 Jul 2022 at 10:44am |
I put Mohawk "Home Expressions" in the bedroom and bought enough for the future bath job, so it matches. Made in USA and went in real easy. Pulled up the linoleum that was under there first. Had decent bare plywood then, nice and level. No regrets. When you pull up carpet BE SURE to get all the damn staples they use when putting in the padding. I re-did the living room, to the hardwood that was under there for 100 years. Both came out nice.
Edited by GSTROM99 - 08 Jul 2022 at 10:47am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12402 |
Posted: 08 Jul 2022 at 12:30pm |
Really? Must be nice. We put Mohawk in our Kitchen/ nook/ dining room when we built our new house. Carnation Instant CRAP. Was scratched almost immediately. Within 2 years, all of the joints that WERE invisible were all "curling up" right at the edge, you can count every board with your toes. The local lumber yard quit carrying it because there were so many complaints. GRRRRRR
