D-17 |
Post Reply ![]() |
Heartland ![]() Bronze Level ![]() ![]() Joined: 09 Jun 2022 Location: Wytheville Va Points: 19 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Jun 2022 at 6:52pm |
Hello Fellers I’m looking for upper brake shoe pins for a D-17 series 4 any help would be appreciated
Rick ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
AGCO...
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87634 |
That’s the lower pins, they are to long and big around.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21850 |
You should be able to get them from the same place you got your brake bands and disc lining from. In a pinch, I have actually used a long 3/8" grade 5 bolt with the head and most of the threads removed. It will work fine.
Is the D-17 the same as the 180 on brakes cause if so I can get uppers for the 180
Same parts.
Ok thanks man
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 800 |
Agco part # 70237217 15.71
Post Reply ![]() |
