Allis Chalmers HD4 |
madtrapper
Topic: Allis Chalmers HD4Posted: 27 Jun 2022 at 9:09am |
Dozer works fine when cold but when it warms up, gets hot, it looses power.
I let it cool down and it will move again. Any help please.
Edited by madtrapper - 27 Jun 2022 at 9:10am |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42191 |
Posted: 05 Jul 2022 at 12:38pm |
Is that in both directions ? Sounds like clutch pack problems of slipping - internal leakage or worn clutch pack with low hyd pressure .
madtrapper
Posted: 05 Jul 2022 at 12:58pm |
Total lack of power. Dozer doesn't have enough power to turn the tracks but if you leave it sit for a while and cool down it works again.
Coke-in-MN
Posted: 23 Jul 2022 at 10:36am |
Is that in all 3 gears ? Seen one where they were running in 3rd and complained no power after a bit - overheating from slipping .
madtrapper
Posted: 24 Jul 2022 at 12:51pm |
It does it in all gears. Works perfect until it warms up and then looses all power
Coke-in-MN
Posted: 25 Jul 2022 at 3:31pm |
Need to check pressure and for leakage , from front pump , torque converter and leaking or worn clutch pack - low hyd pressure to clutches
