bubble burners
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: bubble burners
    Posted: 25 Jun 2022 at 7:21am
been seeing alot of pickups this past couple months with them running on LPG. hadn't seen them for years. beating high gas prices? I don't know the price of LPG right now. what are the prices in your areas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 7:46am
In MO pay a Once a Year $100 Fuel Tax and get a w/s sticker, no highway use tax on LP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 9:17am
Prices seem to vary from $2. to $4. depending on which state you are in......... today
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 9:24am
The local tractor supply fills tanks for $3.99/gallon
Edited by thendrix - 25 Jun 2022 at 9:24am
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 10:34am
The goal is for those people to fill from their household lp tank. No road tax. Was done years ago, for awhile, then states cracked down. Funny tho, these EV zealots, tote the same reasoning of no road tax when plugged in at home, wait till the electric meters are installed that charge road tax for every kilowatt, the tears will be flowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 10:48am
Here the REA and Local Large Utilities require same consideration, to Recharge your EV at Home REQUIRES a 200A Separate Service fed from the pole or pad mount transformer on its OWN Meter, 90A circuit for 240v charging.  Can get a 120v plug in set up but uses MORE energy than the 240v charger feeds, six of one half dozen the other!!  120v only runs 20a but takes HOURS, if Not overnight and that may only make 75-80% charge.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 12:17pm
Here I thought you had been catching farts to run your golf cart.LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 12:47pm
If that's the case ole shammers could start a "gas station"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 1:26pm
Did the Quick Math on the 240V system should the draw be less than 80% of rated Safety breaker, 18,000+/- or 18kw per hour.  Fine if only takes a few hours to reach Full Charge and only a few days per week.  3 hours is 54kw per day and x say 20 days per month 1080kw/month.  That equates to a Homes Use of energy at my given usage and NOT that cheap at around $6/day or $120 + Road taxes per month.  Close to or really right at cost of gas I currently use filling twice a month.  Winter they have to stay plugged in to stop battery from freezing.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 3:15pm
Would not a second service have a separate service charge for line, meter, etc.  Just more cost.
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 3:43pm
One would imagine the utility will have a ‘per month’ charge just for the meter itself, regardless if no kilowatts move thru it.
