Replacing bushing hand clutch wd 45
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: Replacing bushing hand clutch wd 45
    Posted: 19 Jun 2022 at 8:14pm
Hand clutch lever is getting really sloppy . Didn't somebody advertised they have replacement bushings ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 3:48am
It seems like there was a point where they started using a bushing but I could be wrong. You'll likely find the pin wore out. A pain to replace but can be done.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 7:35am
Bushings started at 34450
2 bushings used, P/N 224705
G
knkrein1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote knkrein1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 8:08am
After you replace or install the bushing install a grease fitting. I have done this on several tractors so far.
Ken R.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 7:15pm
Thankd guys
