Friction block for throttle on 7000
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Friction block for throttle on 7000
    Posted: 18 Jun 2022 at 11:54am
Where is it? Mine creeps because it worked very hard and I sprayed oil in there and now it creeps to a lower RPM. Help! Thanks! Dana
Blue Skies and Tail Winds
                          Dana
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2022 at 2:01pm
spray brake clean where you sprayed the oil...
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2022 at 3:22pm
Yup while tedding I stopped and somehow got my 76 inch body under the panel and adjusted the friction discs with a half inch wrench so all’s well. Thanks Ron that’s a great idea I had forgotten. Dana
                          Dana
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 12:14pm
You can get to it from the bottom plate under the dash or the top panel at the front of the cab.  I feel like the bottom plate is a little easier reach, but you have to fit yourself around all the pedals to work under the dash.
Hurst
1979 Allis Chalmers 7000
5800 Hours
