Ca zenith venturi |
ACCA52
Joined: 26 Jul 2021 Location: Grove City PA Points: 14 |
Topic: Ca zenith venturiPosted: 10 Jun 2022 at 7:28pm |
I have two ca zenith carbs with different venturis. One is a 13 then other is a 16. Is one better than the other. Tractor seemed to run very ritch with the 16 in, have not tried the 13 yet, as just rebuilt carb.
ACCA52
Posted: 10 Jun 2022 at 9:06pm |
I found a site that lists the 13 as the stock venturi, so going to put it in and give it a try
Edited by ACCA52 - 10 Jun 2022 at 10:31pm |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90561 |
Posted: 10 Jun 2022 at 10:09pm |
I think the number is the BORE of the venturi in millimeters... 13 mm would be just over 1/2 inch ( .511) ...... the CA is a 125 cubic inch motor... If you had the same carburetor on a 150 cubic inch motor ( example)... then it might use the 16 mm venturi
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 11 Jun 2022 at 6:05am |
Which one I'd use would depend on what your use would be. Farm use I'd go with the 13. If all that you do is pulling and you've run out of power, then go with the 16 and get the A/F mixture correct. If the 13 give you the power that you need for your selected gear and tire size then stick with it. In pulling you can overpower your gear and tire size and do worse than having just a little less power.
