WD45 & D17 series 1-2 final drive
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 & D17 series 1-2 final drive
    Posted: 07 Jun 2022 at 8:57pm
Are they the same or is there a difference between the 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 9:01pm
They would interchange as an assembly, as they are the same ratio. If you look thru AGCO parts, you'll find there are many things that have different part numbers on them. So, they changed things over the years for more strength and durability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 9:13pm
Heaver gears and a lot stronger stub axel. WD  will twist axel once in a while, but have never saw a D17 axel twisted.                       MACK
