D-17 Series IV Hydraulic Problems
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Series IV Hydraulic Problems
    Posted: 28 Sep 2010 at 6:21pm
Been working on a D-17 IV and been having problems with the lift arms not going down.  Took the advice of several on the forum as it being a stuck traction booster valve or frozen linkage.  All the linkage and valve are free.  However the cylinders still will not go down.  Took the pins out of the cylinders to the lift arms; unscrewed the hose and tried to push the cylinder in with no luck.  I can tap it in with a hammer but something tells me something isn't right with the cylinders.  Any ideas?  I just want to be able to use the hydrualics
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 6:28pm
Get a long pipe or bar (5 ft or more) and use it as an extension/lever to the lift arms themselves and with engine off and one of the cylinder lines disconnected hang your body weight on the bar and report back what happens.....if you are BIG that's fine, you're not going to hurt the tractor.
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 6:36pm
Dr. Allis,
I have disconnected one of the cylinder lines and stood on top of the lift arms and still they will not go down.  What does this mean?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 8:35pm
Get a long bar and force them down like I said......if they won't go down with a 5 ft long bar and a 200 lb man hanging on them, there is a problem with one or both cylinders.
