Xt 190 hydraulic pressure
Svnty7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Svnty7 Quote  Post ReplyReply Direct Link To This Post Topic: Xt 190 hydraulic pressure
    Posted: 28 May 2022 at 9:35pm
Greetings,
I have a XT 190 with a hydraulic issue.
800 to 900 psi on the raise function on the remotes, 2300 psi on the lower
Tractor won’t pick heavy implements
When hookup up the right way. When I switch hoses to the down coupling it will pick up anything?   I can’t see how it would be the pump since I have good pressure on one side???????? I did change the relief valve with new one. No change?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 10:06pm
You have a bad coupler.                 MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Svnty7 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 11:29am
Thank you I’ll give that a try
Post Options Post Options   Thanks (0) Thanks(0)   Quote Svnty7 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 11:31am
Actually it does the same thing on both sets of remotes.   Two bad couplers??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 1:06pm
Well...that 2300lb pressure is in the valve stack soooo....changing couplers is cheap and easy...new never hurts anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 6:34pm
Replace both hose ends with correct tips on the cylinder that is bothering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 7:50pm
If your using couplers that are a ball inside, make sure the hose end is the same way. I was never able to get a pointed fitting to work in a ball style coupling or vise versa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Svnty7 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 8:25pm
Tried new couplings on both sides.   Still low pressure on the “raise” coupling. Normal pressure on the low side. It does the same thing on my haybine disc and c mulcher
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 9:09pm
Now, two new couplers to match the hose tips.       EDIT: Just so you aren't wasting our time, when a coupler locks up and movement of the hyd cylinder stops, the engine will labor as the hydraulic pump makes 2300 psi against the relief valve. If the engine doesn't labor when movement stops, you have a bad relief valve, pump issues or low on hyd oil !!!   HYD HOSES ARE CONNECTED IN PAIRS TO THE RIGHT OF CENTER OR LEFT OF CENTER ON THE TRACTOR, NOT ONE ON EACH SIDE.
Edited by DrAllis - 30 May 2022 at 6:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 7:29am
With engine off, will both levers stay in detent?                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Svnty7 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2022 at 8:27pm
Haven’t had a chance to see how much the engine labors when it completes cycle.   They do stay in detent when the motor is of. I’m clear on how to hook up hoses……. Thanks for all your help . Just in case I’m going to buy a complete new set of male and female couplers and try that again
This page was generated in 0.605 seconds.
