190XT camshaft replacement
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT camshaft replacement
    Posted: 28 May 2022 at 10:59am
Last fall i had the hydraulic pump on my series 3 suck up a part of a power director disc and lock up. This tractor had the sump screen removed at some time and i will be replacing that screen. My question is can i remove the front axle assembly and front cover plate and replace the cam that way somehow holding the lifters from above? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 1:27pm
This seem crazy but it works- go to Dollar General and get clothes pins and dowel rods from a hardware store - AC even has this in the fix it manual, tap the dowel rods in the lifter, snap it with a clothes pin - holds it up and works
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 1:44pm
Does anyone know what size dowels? Thanks
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 7:04am
The pan will have to come down to remove the engine oil pump too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 1:21pm
did the series 3 use the cam drive pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 3:17pm
Yes cam driven oil pump and cam driven hydraulic pump
