2 cylinder Buda diesel F.S. |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Topic: 2 cylinder Buda diesel F.S.Posted: 26 May 2022 at 11:05am |
Not Mine seen on Facebook Market place $500
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Unit3
Posted: 26 May 2022 at 5:25pm |
I can’t make it open.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90800 |
Posted: 26 May 2022 at 6:53pm |
when you click on the link, it will put a " /%20 " after the item number on the post... CLick at the END of the title and backspace to eliminate the /%20, then hit enter...
steve(ill)
Posted: 26 May 2022 at 6:56pm |
Missing radiator, missing crank handle, missing some fuel lines.
Has some compression, injectors make noise, fuel pump seems to work. Same pistons as a Allis Chalmers B diesel. Bosche injectors. Cool stationary engine or barge motor. I believe the engine is from the 1940's. I read that the head gasket is copper, valves and pistons are like a Buda Allis engine, so you could get the compression back up. |
