2800 turbo line
ACmutt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Topic: 2800 turbo line
    Posted: 26 May 2022 at 9:48am
When installing a turbo on a 2800 non turbo engine, where do you hook the oil line going to the turbo?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 6:28pm
All the way along the right side of the engine block is the main oil galley. It has the oil pressure idiot light sender attached to it. There should be a plug or two to tap into all along the block. Bigger hole the better. Have you got the turbo drain line plumbed ??
Edited by DrAllis - 26 May 2022 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2022 at 7:01am
Thanks Dr. There are 2 places, one has the light, both are small. There is a plug at the bottom of the engine block, right side right under them. I haven’t taken it out yet but though I could use that for the return? Don’t know if I can get it out, where do you suggest I go with the return??
Edited by ACmutt - 27 May 2022 at 5:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2022 at 2:27pm
That maybe the coolant drain !!!! Ill have to look at some of mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 9:32am
those galley plugs are 1/8 pipe on my 426's and that's where the turbo feed is
