c clutch 8 1/2" or 9"
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: c clutch 8 1/2" or 9"
    Posted: 25 May 2022 at 9:27pm
the clutch is on its way out on my i wanted to order a clutch and have it here before i took it apart,  is there  to tell if it is 8 1/2"  or 9" without splitting it ?
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 4:28am
The "C" Allis should have the 8 1/2" clutch unit in it...I've never saw anything else in them besides that unit...I think only the early "B's" had the 9" unit in them...
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 6:18am
If it has electric start, it MUST have the 8-1/2" clutch. Only crankstart tractors can fit the 9" clutch into the bellhousing with the size of the flywheel. This applies to B,C & CA tractors. Crankstart tractors can possibly have the 8-1/2" either by just useing the 9" pressure plate or redrill the flywheel for the smaller pressure plate. I've seen a lot of Crankstart tractors with a 9" flywheel and pressure plate with an 8-1/2" clutch disc.
Edited by PaulB - 26 May 2022 at 10:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 9:22am
thanks you guys,  i will go ahead and order an 8 1/2"  this time of year its hard to get my own stuff close to the shop for very long
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 12:39pm
At the end, all of the B/C/CA's had the 8 1/2" clutch unit in them...yep, all of the crank start were 9" on the B's for sure
This page was generated in 0.326 seconds.
