8070 power director
allis/cattle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Topic: 8070 power director
    Posted: 25 May 2022 at 7:49am
Would the complete power director from a 8070 bolt into a 7060 ? A friend is having trouble with his and wanted to make it stronger
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2022 at 7:56am
  7060's aren't really known for power director clutch problems. So, what's the whole story ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2022 at 8:01am
We’ll the power director was rebuilt 2 years ago then the motor last year with a new torque limiter it’s slipping again and he’s afraid that the power director will be next. It’s running about 170 horsepower and pulling a 8/16 melroe plow at 5.6 mph burning close to 10 gph
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2022 at 8:54am
Afraid it might be next?  So, you want to just replace it with something that for the most part is the same size?  IDK, doc is the expert.  If I had a spare $5, I'd say when the motor was redone, something is amiss with the rear main seal, leaking on the torque limiter.  I don't understand what symptom you're seeing that makes the PD look bad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2022 at 8:58am
Torque limiter should have had a shield kit installed when it was apart the last time. If the power director was just done 2 yrs ago, it should last for many ore years. Do the TL correctly and get on with farming.
This page was generated in 0.079 seconds.
